The new engine is designed to be distributor less unfortunately doesn't look like a cheap conversion
Then the new engine is useless to you as a swap. It probably has hardened seats in the head.
What year is the newer engine?
Refresh my memory. why are you replacing the engine?
Poke around Access Denied and see if you can find something that will work. You already have a tone ring or a crank sensor setup. The rest isn't that complicated. A multi coil setup is the best. No distributor. If you got all that already, all you need is a driver box with timing
Ahhhhhh summitracing. com
