free fiero!
exotion
Got her in the mail
7394
exotion-
Your attachments show up as black & white in my view.. maybe it's my browser ?
I do speak GM, but mostly chebbie.. :thumbsup: You will be fluent in GM in no time..
exotion
exotion-
They are in color for me
This 2.5 is an iron duke the same as the s10 just a little weaker
gfp55
I won't be much help. I don't speak GM :laughing:
9k=
If you have ever worked on these parts and a lot others, you speak GM. Mopar bought these part and tons more from GM.
gfp55
Got her in the mail
Its easy. Remove the engine from the car set it next to the replacement engine and switch all the sending units, sensors, brackets, etc from the engine that came out of the car to the engine that is going back in the car. The sending unit,sensors,etc may not match volt values. Volt values changed from year to year most of the times.
exotion
Biggest issue is my old engine is a distributor ignition, the new one lacks distributor :)
gfp55
Changing things over is no big deal. Its easier to go from electronic to distributor. If you look at the harmonic balancer on the new engine, there will be a reluctor ring and a crank sensor and none of that on the old engine. You are making the new engine old school ignition. You will have to go old school or you will need to get computers and things, wire harness, etc. You can get rid of all that stuff. if you need so help PM me and I can walk you though it.
