rebelrouser1953
- Mar 5, 2025
- 1
- 5
What tools do you need to remove the plastic oil drain and replace with a rubber hose on my gravely zt60 zero turn. Thks
There is a plastic fitting that is screwed into the lblock which has 2 flat sides on it that needs to be removed to install a new rubber drain hose. I’m trying to figure out the right tool to remove that piece with very limited space. Thksif you are not going to reuse the old drain just cut the tube off the drain. Loosen the lock ring screw the drain out and install the new drain hose. I never have to remove the engine or loosen it.
This Kawasaki motor is on my zt60 gravely zero turrnThere is a plastic fitting that is screwed into the lblock which has 2 flat sides on it that needs to be removed to install a new rubber drain hose. I’m trying to figure out the right tool to remove that piece with very limited space. Thks
You’re a smart man…. That looks like what I needSorry, It is an in shop made tool with 15/16 spacing. I make a lot my own custom tools.
