FR730v kawasaki
rebelrouser1953
What tools do you need to remove the plastic oil drain and replace with a rubber hose on my gravely zt60 zero turn. Thks
hlw49
if you are not going to reuse the old drain just cut the tube off the drain. Loosen the lock ring screw the drain out and install the new drain hose. I never have to remove the engine or loosen it.
rebelrouser1953
There is a plastic fitting that is screwed into the lblock which has 2 flat sides on it that needs to be removed to install a new rubber drain hose. I’m trying to figure out the right tool to remove that piece with very limited space. Thks
rebelrouser1953
This Kawasaki motor is on my zt60 gravely zero turrn
Otherwords you need a tool like this.
That fits like this.
This is the one I use to remove an install these oil drains as a normal crowfoot wrench will not work in the limited space.
rebelrouser1953
What is the name is the name of that tool and what size is it. Thks
Sorry, It is an in shop made tool with 15/16 spacing. I make a lot my own custom tools.
