I have carb issues this Spring. First, needle was gummed up causing float to stay down and although the engine ran, fuel was flooding the float bowl and pumping out. Got that fixed.
Next it was surging or hunting. No doubt a lean condition. I removed the carb, removed the float, needle and main jet, and that's as far as I could go. Seems pilot jet is under a welch plug so a complete carb kit would be required. So what I did was to soak it for about 1 hour in an ultrasonic tank, then blow it out with compressed air alternating with some carb cleaner spray. Re-installed the carb. Some improvement. At full speed it seems "almost" normal but at half speed it hunts very badly. It was surging at all speeds before.
Looked up the carb and it's a whopping $377 Cdn from Husqvarna, however there is an aftermarket one that looks promising (based on the reviews): https://www.amazon.com/HuthBrother-15004-0985-Carburetor-11013-7047-11013-0726/dp/B08CK3NT2P/ref=sr_1_1?crid=19DCNUB6HXI10&keywords=Huthbrother+15004-0985+15004-0986+Carburetor&qid=1684083584&sprefix=huthbrother+15004-0985+15004-0986+carburetor,aps,74&sr=8-1
Any advice or other thoughts on the matter? T-Y.
