dpoole1375
- Feb 7, 2021
- 1
- 4
This is just to inform about a Kawasaki engine problem I fixed to help others. I bought a Gravely 52hd back in 2013, had the Kawasaki FR691V and smoked from day one at startup. Took it back to the dealer under warranty at the time, and they could not find a issue with it said I would have to call Kawasaki about the engine. Called Kawasaki and told them about the issue I was having and said that was "Normal". Well its not normal for blue cloud of smoke at startup almost every time. So Kawasaki offered no solutions for the issue. So I used the lawn mower for the next 7 years keeping an eye on the oil level, which it used very little but would drop from the full mark. So last year (2020) the problem finally showed its head. I was mowing and the engine just stopped. Had to pull the fuel line off to get it to crank back up. It started and I finished mowing my lawn. Put the lawn mower up after mowing and started to troubleshoot the issue. Pulled the air filter tube off the carburetor and noticed a pool of fuel sitting at the 90 degree bend in the intake just before the carb. Cleaned the fuel out of the 90 and tried to start the engine back up. Raw fuel started coming out the exhaust. Pulled the float bowl off the carb, then pulled the float and needle. The needle was the 2 piece needle with rubber on the end. The rubber was cracked and broke. So I ordered a new needle and gasket set for the bowl. When the new parts came in I noticed that the needle was a 1 piece metal without the rubber (guess Kawasaki knew this was a issue and changed it, but didn't tell owners about it, what else is new.) Anyway, put the new parts in the carburetor, and engine did not smoke at startup even after sitting for 2 months. So the conclusion is if you have this model engine of this same year and it smokes at startup, this is the issue. The giveaway is the fuel sitting in the intake with the engine not running, which should be dry as it is now with the new parts. I read all the forums and could not find this issue for smoke at startup.
