FR691V - Low IDIL rough / pulsing
Walkerj001
I have a Gravely ZT HD 52 with a Kawasaki FR691V and having some issues at low IDIL. My model of zero turn is 991083. It randomly acts like it wants to stall or cut off at low IDIL , but when throttle is up no issues. New fuel filter, spark plugs, air filter, gas cap and oil changed start of season, fresh gas, carb torn apart / cleaned and still having issues. I pulled off gas line going to carb and gas is coming out quick and I didn’t see any clogs in gas line. I put a video below of how it acts. Any help would be very appreciated as I’m lost where to go next.
Link to video:
Sounds like an obstruction in the idle circuit to me causing surging
So back off withthe carb and pay strict attention to the idle passages, both fuel & air .
Boit4866
How many hours of run time on the engine. Have the valve lash ever been checked and/or adjusted?
twernicke
I had the same issue. I tried replacing the plugs, fuel filter, air filter, checked carb springs etc. I finally gave up and simply replaced the carb and the problem went away.
