Pools are too much FUN... and while you are using it & you have some kids around that will NEVER forget their times at it... It's got to be worth what ever you do to keep it...
Your electricity use is not that bad...
"1.5 HP, 14 amp, 220V pump motor ...on a timer... shut the pump down for 8 hours per day..."
assuming your power is around 12 cents per KW... That would be $175 a mth and about $265 a mth without the timer limit...
So al in all for the number of bodies getting some great use from it ... I'd say :thumbsup: well worth the $$... :smile:KennyV
