Chad Vogel
- May 19, 2016
- 1
- 4
I'm new to this site so any help would be appreciated. I'll give you a rundown of what has been going on.
This all started with my ignition switch going bad. I have replaced it with the correct model thru Ford/New Holland and currently have it wired correctly. I say that because the first time wiring it, I had wires mixed up on the switch. Now that I have corrected that issue the mower starts every time. However the mower will run at full throttle with blade running (or not) for a short period of time, then it will die/blowing the 25A fuse. The mower will idle for over 30 minutes without blowing the fuse. The 25A fuse is not the main fuse to the system. That fuse is a 30A. Could this issue be the voltage regulator? Or something else?
