I was doing a little prep work, getting ready for the new engine that is coming. I had to replace the line for the left tranny. Where it goes under the fuel tank, and then down through the hole in the frame... the line cracked, or got chafed, and let the fluid drain out. There is still fluid in the tranny, and it is a nice green color.
1. What color should it be?
Talked to the local Cub service dealer, and picked up a gallon of the Cub Cadet Drive System Fluid Plus. Thar was a little spendy. THEY assured me that was what I needed, and that was what it came with. I called Cub, just to verify, talked with Ed. HE says that what they have been using is a 20-50 syn blend, and mentioned Shell Rotella synthetic.
The mower is a 2005 RZT50 (according to the manual), with a Briggs 22 intek. Does anyone have input on this fluid issue?
1. What is the proper fluid?
2. What color should it be?
3. When I refill the reservoir, is there a "burp", or bleed procedure? The res was empty due to the cracked line. The left tranny is not leaking, so I just need to fill the res, and the line to the left side. There are no leaks on the right, but I double check the line, while I am in there.
