Was going to mow for the last time this year but my mower, a ferris 1500z will not start. It ran and started up fine the last time it was used. I have fuel in the fuel bowel and spark at the plugs. There is no fuel getting to the plugs. I sprayed carb cleaner directly into the carb, took the hose off going to the air filter so I could get at it. It will not fire and the plugs are dry. The fuel solenoid clicks off and on. I cannot find a wrench thin enough to take it off to actually check it. What should I do next, thanks for any help.
