Hi all, just stumbled onto this forum, seems to be the most popular one I could find. So hopefully you can answer a few of my questions.
To start I have a freedom Z (unsure of year, bought used) with about 1000 hrs, was repowered with a 27hp briggs at about 750hrs.
Three things I have questions about.
1. I have what looks to be a tensioner pulley, right under the seat that is just barely bouncing and rubbing on the metal under the seat. Not sure what to do about it short of replacing it. But that looks to be awfully difficult. It rubs the metal and the sound is pretty loud and annoying, but doesn't really affect the function of the mower. But I'd like to get it fixed before the pulley wears through the sheet metal.
2. I'm pretty sure that the engine should charge the battery while running, correct? Mine doesn't seem to charge. I have a few LED lights I use for mowing after dark, and they can kill the battery, and no amount of running the mower will recharge it. Battery is brand new this spring. Same for using a sprayer, it'll kill the battery eventually and the mower won't charge it. Where do I start troubleshooting?
3. Hydro adjustments? The left hydro will slow to a stop when you let off the handle, right side will maintain current speed when you let off the handle. Also the right hydro goes a bit faster in revers than the left. Is there any adjustments that can be done at home?
I'm a pretty competent mechanic, so if any of this can be done without major disassembly or any specialty tools, I'm all for giving it a shot. Do have a Scag dealer nearby if necessary.
