thespyderbyte
- Feb 16, 2017
- 7
I'll look for that number. I did replace the fluid filter with a NAPA gold filter, and the loss of hyd fluid has stopped. The skid plate I had to remove to get to the filter had only one bolt in it, requires two, so replacing the skid plate will put another bolt. Think the vibration of the skid plate made the filter to leak, had a mark on the side of the filter. The engine is a Kohler command 22 on a commercial procut 61. Will change oil, fuel and oil filter, sharpen blades. I like taking a impact gun and taking the blades off, just have them drop to the ground. Quick and painless. Model is CV22S. This critter isn't new by a long shot but still a good mower and hope to use it a lot still before buying another.
