Ferris ISZ
LarryDThiemann
The electric clutch (5022334 or 525944) has two wires. One wire broke off flush at the clutch. Is there a fix for this?
Thank You
The grass is growing fast!!!!!
Carscw
The electric clutch (5022334 or 525944) has two wires. One wire broke off flush at the clutch. Is there a fix for this? Thank You The grass is growing fast!!!!!
I have cut the plastic where the wire goes into the clutch. And connect the wire back.
There is a you tube video from "Taryl Fixes All" showing a repair by driving a screw into the base where the wire broke off, soldering the wire to that then potting the whole lot up for strength.
Look it up, should work.
