stingray157
- Mar 31, 2013
- 1
- 3
Hi
I have a Ferris 48" commercial walk behind for home use. The unit ran fine and after mowing I tapped it on the ground to knock the grass of the mower deck. After I did that it stalled and would not restart. After looking into it, the only way to get it to start is to disconnect the kill switch wire which runs from the coil to the key switch. Unplugged, it will start just fine, when I plug it in there is no spark to the spark plug no matter what position the key is in. Anybody have any ideas on what I should do? Replace key switch?
Thanks in advance for your help on this aggravating issue.
