grassmauler
- Aug 29, 2023
- 7
At first it would only turn over, but wouldn't start. I checked for and found spark. I then sprayed starter fluid into the carb and it started until that fluid ran out. Turned the key off. Sprayed more starter fluid, turned on key, heard a single click then all was dead. Replaced burnt fuse. Attempted again. Fuse immediately blew. Your thoughts? How can I check the fuel pump?
