fd620d pushrod falls out of rocker on one valve
Not much of a JD dealer if they can't put piston rings on.
Swap valves and see what you have. Measure both and see what you have. Like Rivets said, incorrect valves?
Hey the local dealer couldn't find a bad spark on Stihl Hedger or a loose fuel solenoid connector on a Z925A. So would you expect them to be able do anything that requires more brains?
On of my customer brought a brand new Z950M and will not let them even touch it repair wise.
