fd620d pushrod falls out of rocker on one valve
Willibe
Is your push-rod bent? Roll it on a sheet of glass to find out.
I not only rolled it on a flat surface, but used a straight edge as well. I also switched it with the other existing pushrods. Everything checks true.
Willibe
Take a picture of everything you are seeing. Will help a lot. Lot of times we hear someone has cleaned or replaced everything and it still doesn't run, like your post. Show us what you are doing.
I want to see a picture of the cylinder cooling fins and valve guides.
Willibe
Slomo, here are the pics.
You can't roll this kind of push rod. There are balls on the ends.
From what I can see, the adjustment stud "looks" like it is worn down to a chisel point??? Pic has a light bounce glare and is blurry at the spot in concern. Is the adjustment stud the same size and shape exactly as the adjacent one? On top of the jam nut, both adjustment stud lengths "look" the same. What do you have below?
I’ve reread this thread and have a couple of stupid questions. Do you have the part numbers for both the replacement valves and cam? Do you have the old valves? Reason I ask is that something doesn’t look right in the pics. On the loose valve the keeper looks like it is sitting almost flush with the end of the valve stem, while the other looks about 1/16” above. I’m wondering if you have the correct cam and valves installed. Also include your engine serial numbers please.
Hammermechanicman
The height of the IN and EX valve stems should be within a couple thou of each other with valves seated.. take the rockers off and put a rule across the end of the valve stems. It should be level with the head. If not you have a valve problem. Springs, retainers and keepers should look the same on both valves when both are seated. Tappets, pushrods and rockers are all the same so you can swap them around. I am going to assume you have the engine sump cover on when checking valve lash.
Can even be a loose valve seat though I have yet to one on a Kawasaki engine; but always possible.
Also on that loose valve, the oil seal looks deeper in the head. Valve guide moved down in the picture? Sticking valve guide not allowing said valve to close all the way up? Valve seat out of pocket like StarTech said?
Not much of a JD dealer if they can't put piston rings on.
Swap valves and see what you have. Measure both and see what you have. Like Rivets said, incorrect valves?
