NonameemanOn
- Aug 27, 2022
- Threads
- 1
- 4
Hello
I recently installed a new fuel pump on my lawnmower. I checked the fuel pump by removing the hose from the outlet of the pump. I dumped some gas into the hose feeding the carburetor. The engine started but the fuel pump was not pumping any gas. There is gas in the line from the gas tank and gas filter to the fuel pump. Is there anyway that I am not getting a proper vacuum from the valve cover or is that impossible. Did I buy a faulty pump.
Thanks
Thanks
