Fastrack S/D cranks, will not start.
mwe333
Hi all.
The first start-up of the season and my Fastrack S/D cranks nicely but won't start. My transparent fuel filter shows only a few drops of gas. I switch tanks and the same thing. Any Ideas?
Thanks.
Mark
reynoldston
Start with fresh fuel and filters. Then go from there.
First check is the fuel solenoid on the carb.
If it isn't opening then the fuel can not flow anywhere, including through the filter.
Then pull the fuel line off the carb and crank the engine checking for fuel flow.
If it is bad then pull the valve between the tanks off and check it does not have crud clogging it.
Remember to drain your tanks first .
