theplayer11
- Jun 3, 2016
- 3
- 15
Manual says red grease or high temp lithium. I have Lucas X-tra which is Polyurea according to data sheet..BUT then underneath data, it says it is a shear stable. According to grease compatibility charts, conventional Polyurea is not compatible with lithium, but Shear stable is. Google search shows a few posts stating Lucas X-tra is not compatible because it's conventional Poluyrea. It clearly states it is a shear stable product, so I'm OK to pump the Lucas into new 600z spindles?
http://lucasoil.com/pdf/TDS_XtraHDGrease.pdf
