lawn mower fanatic
- Jun 8, 2012
- 321
- 6,749
Well if you don't like the exmark or toro because they are under powered, you're not going to like the JD either because the C52KS, JX90C and the JX 90CB all run the same Kawasaki engine the FJ180V KAI. They do make one with the caster wheels it the JS 63VC John*Deere JS63VC Mulcher Walk-Behind-Mowers
Well yes I saw that mower and knew it had the front caster wheels, but it is not in the same commercial mower lineup as the JX90CB. And yes, I also noticed that the JD has the Kawasaki engine, which is unfortunate.
