Exmark 708 engine crankcase pressure
Savage
Just for general knowledge......
708cc Exmark engine:
How does the crankcase maintain pressure with the drain hose running up the side of the engine connected to the engine cover?
Does the drain hose act as a crankcase vent as well?
Generally, the oil drain is plugged with a bolt.
Thanks
No the drain is a drain pure & simple
Crankcase vacuum is maintained by the breather which plugs into the back of the air filter
The engine end has a reed valve
Occasionally the valve gets crud stuck in it so fails to seal.
This usually causes the engine to become smokey.
Savage
I haven't taken this engine apart yet.
2019 model, this set-up is new to me.
I was surprised to see they spent the extra two cents installing a hose.
