Excessive turn radius when turnin right. correct turn radius when turning left
John Dean
  • / Excessive turn radius when turnin right. correct turn radius when turning left
I own a 1999 model craftsman 20 hp lawn tractor. It will not turn to the right vert sharply but turns to the left as it should. Any ideas what might be going on herr?
Carscw
The rod going from the steering gear to the left front wheel is bent
(( racing is the only sport that you need two balls ))
SeniorCitizen
If it's an MTD product it's probably normal. The first one I drove hit a tree. Poor tree, I felt so sorry for it.
0ーF
DaveTN
Could possibly be the "Rack and Pinion" jumped a few teeth. When they get worn the bushings get weak and the steering pinion starts slipping.
jakesmurray
On some mowers they will turn more sharply to the left because that is the trim side, or the side without the discharge chute. It's better for going around trees, etc.
RED7218
Sheet metal axle is bent?
Carscw
