I have a Scag Wildcat Zero Turn- 27hp Kohler engine. Model CV740S -- This ran fine 2 weeks ago. Now, my problem is that it won't crank. When testing the battery, it's coming up short at just 10volts. Only 10volts to solenoid too. The solenoid barely clicks once. I get several clicks coming from instrument panel, but it then stops. When I attach a jump starter to the battery, the solenoid goes nuts with clicking, and the motor will try and spin, but not enough to turn over. Do I have a bad starter? AND, a bad battery? What are the odds of both going out at same time?
You guys have helped me out a lot. I very much appreciate it.
