Hi all,
I have a Craftsman zeroturn with a Kohler Courage 24HP v-twin with 17 hours on it. (I know, Courage to buy one...) ITs on a Craftsman 54" zero turn which is the same mover as the Cub Cadet ZTR zero turn...
Starting:
Cold: just cranks, no start. Cold could be anywhere from 80f-50f ambient so far.
Warm start: no problem
Idle: perfect
Running: perfect
Mowing: perfect
Oil: fresh
Fuel: fresh
So to start it cold I take the air filter off, shoot on shot of starting fluid in it and it starts up and runs perfectly.
Anyone want to guess why this is? Thank you so much for any help you can give.
Starting:
Idle: perfect
Running: perfect
Mowing: perfect
Oil: fresh
Fuel: fresh
