Engine won’t start
Scrubcadet10
Moderator
Staff member
well, i see the fuel pump mounted up top next to the valve cover.
Pull of the line i marked in RED and crank it... it should spurt out fuel. If not, Pull off the line i marked in green, and place your finger over the hose nipple on the pump, you should feel a pulsing action. if not.. the diaphragm in the pump could be bad, OR check that you feel a pulse from nipple that is marked in BLUE.
It's not common for these pumps to fail, but i've replaced a few.
AdamHword
Fuel line, fuel tank and or fuel filter could be blocked. Find out which. If yours has a fuel pump that might be bad too. Something in the fuel delivery path is your issue.
Remove the tank and clean it out good. Replace fuel lines and filter.
Thanks I just went out and bought a new fuel line and I’ll try to figure it out beyond thag
AdamHword
Ok so I’m not getting any suction at all and no fuel came out of the top
Scrubcadet10
Moderator
Staff member
Are you getting any suction from the valve cover/pulse side?
whatever that hose i marked in blue hooks too, take it off and feel for pulse from the engine. Most likely it is the pump though.
before buying a pump, you may try cleaning this vent on it. I've never fixed on like that, but i have read about people cleaning that vent and fixing a no pump issues.fuelpump.png
AdamHword
before buying a pump, you may try cleaning this vent on it. I've never fixed on like that, but i have read about people cleaning that vent and fixing a no pump issues.View attachment 57357
I am getting some suction from the engine so it’s probably the pump
Scrubcadet10
Moderator
Staff member
most likely.
that's the same Mikuni pump as on my Kawasaki mule.. i replaced it about 4 years ago with a Chinese copy of amazon and it's still going strong.
AdamHword
most likely.
I was doing a little experiment and found that it doesn’t spit fuel while it’s on the angle but it does when it is flat. Is that a pump issue or a engine issue?
Scrubcadet10
Moderator
Staff member
hmmm... let me look at another picture of that engine to see if the fuel pump is orientated differently.
EDIT:
Yeah, thats how the pump comes mounted from the factory...
AdamHword
EDIT:
Hmmm ok well I’ll order the new pump. You wouldn’t happen to know what it’s called Would you? I looked on Amazon and see some But they don’t look exactly the same
Scrubcadet10
Moderator
Staff member
I'd hold up on ordering a pump, see what others might have to say....
