- Sep 24, 2017
- Threads
- 280
- 6,789
well, i see the fuel pump mounted up top next to the valve cover.
Pull of the line i marked in RED and crank it... it should spurt out fuel. If not, Pull off the line i marked in green, and place your finger over the hose nipple on the pump, you should feel a pulsing action. if not.. the diaphragm in the pump could be bad, OR check that you feel a pulse from nipple that is marked in BLUE.
It's not common for these pumps to fail, but i've replaced a few.
