The "can" at the bottom of the carburetor is an anti-backfire solenoid. All it does is stop your fuel flow when you shut your engine off. I have a Kohler courage 20hp engine on my mower and I took a Dremel and cut the plunger off the solenoid and installed a manual shut off valve (about $4.00) . Just remember to turn the shut-off valve on when you get ready to mow and off when you are done. If you don't shut it off when you're done you stand a chance of your fuel siphoning into the crankcase---not good!!
Thanks for the head's up, Jerry. I used my grinder and took the plunger down to the top of the seat, re-installed it and mowed all afternoon. I have not yet installed a fuel cut-off so your advice was very timely " chance of your fuel siphoning into the crankcase" -- so I ran outside and pulled the fuel line at the carb and stuck it up in the air above the fuel tank, tomorrow I will find a fuel cut off. Thanks,
