spencerrubin222
- Sep 6, 2016
- 1
- 3
Will an 18 hp briggs v twin fit in a 2010 craftsman lt1500 frame? the original engine was a 17.5 hp briggs
:welcome:Will an 18 hp briggs v twin fit in a 2010 craftsman lt1500 frame? the original engine was a 17.5 hp briggs
:welcome:
This is the best laid out specification pages for B & S
Look up your old engine and compare the dimensions with the new engine then go measure your mower.
V twins are longer than singles if the air filter is between the cylinders
V twins are wider than singles so it might foul on the hood
heights are almost the same
And you will need to buy new control cables
Sorry,
I was so busy double checking the data I forgot to post the link
https://www.smallenginesuppliers.com/html/engine-specs/briggs-engine-specs.html
There is a drawing of each engine under the description & photo complete with engineering drawing.
