Good evening.  I'm new to the forum & I am hoping I can get some guidance from the members here.  I have a nearly new Ferris IS700 with the 27 HP Briggs engine.  The machine has 55 hours on the meter.  I purchased it in July 2016.  I've had zero problems with it throughout the 2016 season, and no problems for the first 4 cuttings of my 5 acre yard for 2017.
Several times today, I would stop mowing and let the engine idle while I was pulling a weed or to grab a quick drink of water. The engine idled just fine. When I finished my last pass, I turned the blades off, and moved the throttle to about mid range while I traveled back to the garage. The engine started to surge like it was running out of fuel. When I stopped to open the gate and idled it down, the engine nearly died. I thought maybe the gauge was reading wrong and the tank was empty even though it needle was pointing to 1/4 tank. I pushed the throttle all the way open, and the engine seemed to run OK. I idled it back down & gave it a little choke, and the surging stopped.
Just to be sure I had plenty of fuel, I filled the tank. The problem continued. Next I removed the fuel filter. I blew through it with no problem. (No matter how well you wipe it off, you still get a taste of gas in your mouth
)  Just to be sure, I ran into town & picked up a new filter...the problem is still there.
I did notice when the engine is running at 1/2 throttle, the fuel line between the filter and the pump moves with the engine surge, like it is having a hard time drawing fuel from the tank. That makes me wonder if I have a restriction up stream of the filter, maybe in the 90 degree elbow that is attached to the tank? Maybe something inside?
I am going to pull the fuel line off of that elbow tomorrow & stuff it into another fuel source to see if the surge stops.
IF that elbow is partially plugged or if the pick-up tube inside the tank is plugged, do any of you know how to remove them from the tank?
Any assistance or advice would be greatly appreciated.
Thanks in advance.
Thanks in advance.
