Hi everyone, I wonder if anyone can help with my Walker MBK-23 Kholer EFI mower.
All was fine until I had to replace the fuel line. I manually primed it by squirting fuel into the pipe from both ends and also filled the line down to the engine before reconnecting.
She took a while to fire up with coughing and spluttering until I relaised that the problem was the throttle position.
She runs just fine on idle however when I attempt to increase the engine speed, it just won't take it and coughs and splutters; seemingly starved of fuel. I have ruled out the air filter being the problem and having checked all connections, I am not completely stuck.
Any guidance will be gratefully received.
Thanks,
Andrew
Thanks,
Andrew
