Jerry YTH2148
- Jul 23, 2020
- 1
Engine stops when clutch brake pedal is released. I have a Husqvarna yth2148, I was replacing the deck bearings so I removed the deck. While I had the deck out, I decided to replace the drive belt as well. I removed the belt, got a new one and installed it. The only wires I disconnected were the two ground wires at the rear of the tractor. I did however remove the pto clutch briefly while I installed the belt. I reinstalled the pto clutch and rolled it out. I rode around the yard to make sure the mower moved backward and forward. I then reinstalled the mower deck and pushed the mower out of the basement. I started it up and was going to start mowing as I started moving, the seat moved and the mower stopped. Thinking I may have broken the seat switch, I went to the local mower parts supply and obtained a new switch. It would start but when you let the clutch brake pedal out the mower would stop running. So I replaced the interlock switch next. This did not fix the problem either. Any other suggestions? I checked all of the wires from the seat switch and the ground wires with a multimeter and they appear to be okay. All of the removed switches appear to be working as well. So not sure what I should do next.
