Can't see it myself, which ones exactly, folks need to know if this is "actually" the case?Some later units now only use the fuel shut off to kill the engine, in that the spark is not killed when the switch is turned off.
Thanks for the help i got the mower running againIt is a 7000
It is a 7000 engine, i donot hear a click when i turn on the egnition switch. it starts runs for 1-2 seconds and dies. i checked the oil and i dont smell gas in it.
Thanks for the help i got tthe mower running againIt is a 7000
how'd you fix it?Thanks for the help i got the mower running again
