I had a zero turn come into the shop. The guy said that they had had the engine "rebuilt" and since then no one could get it running. I finally got it running - it had a lot of electrical issues - but once I did, it wasn't running right. Without the air breather installed it runs OK, but it is spitting fuel out through the carburetor. A lot of fuel. When you re-install the air breather, the engine runs bogs down and and runs rough.
I checked the carburetor. The float is not adjustable. The carb is clean and the needle and seat are functioning properly.
I checked compression and both cylinders are running at 150 psi.
I still want to think that it's a leaky intake valve - or one that isn't seating right - but with the compression so high....
I don't own a leak-down tester. I was thinking about getting one, but I was wondering if I couldn't just attach a compressor to the cylinder? I'd really only need to listen for leaking air, not necessarily read a gauge.
Any thoughts?
Any thoughts?
