Engine Spitting Fuel Through Intake
rebeltaz
I don't think that's a valid check of the compression release but I'm not familiar with your engine. There wouldn't be much point in a compression release still being open at TDC.
Back to the workbench :) I'll pull it back down and pull that cam out.
Kent82
Did u ever resolve this issue? I’m having the same thing happen
hlw49
Did you by chance check the lift of the cam to see if the valves are opening as they should.
hlw49
This would indicate a worn out cam
7394
Might not get a response, that member has not been here since Nov 5, 2019.
