Have you used the new torque spec and pattern? Have tried to copy file and attach the file but the computer won't allow it. So here is th jist of the service bulletin.
1 New design head bolt, with new torque pattern. No part number given.
2. Tighten 1/3 value, then 2/3, then final torque.
3 new torque 250 in ib-in or 28.2 Nm
4 pattern 1. bottom center 2 top center, 3, botom center left side, 4 top right, 5 bottom right, 6 top left, 7 bottom left, 8 left center top.
6 2 4
8
APSI # 87
NOVEMBER 2012
SUBJECT CYLINDER HEA D TORQUE CHANGE
MODELS 21OOOO, 280000, 310000, 330000 vertical shaft engines
