Engine Replacement
Drama
I have an Kawasaki® FR691V Twin 23 hp/726cc. It is on an ariens ikon xd 52. I want to replace it with a FS691V. Will this work as a replacement? The FS engine is slightly large. That is about all I know.
MParr
What’s wrong with the current engine?
hlw49
If I were doing that I would go with the FS730 it is the same block.
Drama
The old engine lost compression with a bent rod.
