Engine rebuild
I gave up on geting them bored and now do it myself.
Problem is very few people get mowers bored so very few shps have the faintest idea of how to do the job and in particular how to mount the cases.
Most car engines are bored by bolting down either the sump or the head so when confornted with a mower engine rather than make up an L block closing plate to bore the engine they just fit it by the head bolts and you end up with an oval bore.
I have one bored about once every two to three years. Usually just replace the engine, unless there is no other engine option, or too expensive to replace, like the $3000 kawasaki engine for a JD gator, or one of the older JD's with the K series engine with no replacement option available.
motoman
I looked around a bit and found that the feeler pull technique seems relegated to antique or older engines. And the discipline described is all the way from "a feeler gauge" pulled by hand to "a 1/2 strip of shim stock pulled to inch pounds or foot pounds," depending upon the manufacturer. So that approach does not really help - too imprecise. Best to make careful meaurements which probably involve a tri-point bore gauge. Perhaps a motorcycle shop "might" be the best source, if a good one can be found. Rivets tips on rings includes end gap filing to manufacturer spec. Reringing should be seen by newbies not as a solution in itself , like o ringing a leaking faucet. Won't work.
Hallettoil
Had my Honda motor re boarded with new over sized piston & rings. After putting it back together it runs but a lot of smoke & not much power. Any suggestions?
Have you done a compression test?
Shot in the dark..... what oil are you running in on?...that is assuming you've done the valves etc
To clarify my post, I do not recommend filing rings to change ring end gap. I wanted to know what the end gap was of the new rings. If the rings installed were not the corrected ones for a newly bored cylinder, the end gap would have been too large, allowing oil to bypass. Also, if new oversized rings were used, but not an oversized piston, the same problem would occur.
reynoldston
My first question is, did you check the ring end gap in the newly bored cylinder before installing? Your cylinder my be bored correctly, but you received and installed the wrong rings. Second question, are the rings installed in the correct order and proper edge facing up? Third, did you replace the piston also? Can you post the following info:
1. All numbers for the engine.
2. Part number for the ring set.
3. Part number for piston.
4. What diameter was the cylinder bored to?
5. Was the block washed and cleaned multiple times before reassembly.
6. Are you sure the rings were staggered when install?
This will help us diagnosis possible problems.
When I first read this thread this was my thought. I agree with this post. Ring gap and if the rings were installed right???
motoman
Sorry Rivets...the filing end gap is my statement. Still hold to it, however. And a slight chamfer on the outer edges of the ring ends. :ashamed:
