Engine problem.
The starters you are buying are not junk.
Does it get to where it does not work at all?
Does the starter get hot while it's cranking?
A couple things that help starters go bad
Cranking to long without giving time to cool off.
Battery not getting enough amps to the starter.
I do not think the starter is your big problem.
Should not have to crank the engine that long before it starts
When I first received the starter It started perfect for about 10 starts then started doing this It does this to all starters after 10 starts It does this.
