The engine is leaking oil under the carb & muffler assembly and I cannot see where it is leaking from.
On the attached diagram, part # 92049B is called the oil seal.
I am thinking it is that ???
Also, I cannot see what that attaches to, do I need to remove the engine to replace that part ??
Thanks!
Thanks!
