engine break in on new mowers
motoman
In this thread knowledgeable people have responded. Years ago I read wide eyed the report from inside Porsche where the newly built AC engines were started, warmed up and pegged @ 7000 rpm. That after very old wives' and folk wisdom suggesting various remedies. Like sprinkling Bon Ami in each cylinder to seat the rings, ouch. Assuming round bores, proper rings, etc I guess such initial loading will not hurt, in fact help........if you have Porsche precision. Perhaps the middle ground and making sure there is adequate oil. Oh... and my favorite. Why don't mfgrs install an oil pressure gauge on every dash of every AC powered rig? Even if only some glanced now and then at the readings many failures could be avoided. Or at least BIG,RED idiot lights? (Perhaps some do).
I am not sure a big red idiot light would do it in some cases. More like a big hammer to hit them on the head to get their attention. And even then some wouldn't know what just happened.
I bought some 2 1/2 " dia key rings and had some promotional key tags made.
I hang these around the dip stick on mowers when I return them & suggest that for safety reasons ( kids can't accidentally start the mower ) the owners should leave them there.
Logic behind this is if you take the keys from around the dip stick there is a better than average chance you will check the oil before you start the mower.
Best one was a customer who say a big oil puddle under the mower so they started it to move it out of the way to see where the oil was coming from.
Exit piston crankcase left.
For many years I used to flood rings with oil when reringing engines however some long conversation with John Heaney ( Triumph race tuner ) soon had ne doing dry ring installs. no idle after first start and on the road strait away, adjust the carboy when you get back.
Rings generally bed in strait away and have never had a failure since.
Boobala
Ya'll settle down now, before I report ya's to the ...... NO testosterone or Viagra List-keeper !! :laughing: :laughing: :laughing: :biggrin:
jekjr
A lawn mower cuts grass wide open. An air cooled engine cools wide open. Very seldom and momentarily at that do we run them any other way. Changing the oil and filter at the first interval mentioned in the book in my opinion is he most critical thing one can do for a new engine.
tigercat
I never had valve or ring issues in any of my engines by following this method. I'm 53 so I've been running engines for a few years now.
Snow blowers, lawn mowers, tillers, tractors and my cars are all done the same way. I don't follow a special break in procedure on anything I own. When the machine is brand new, I respect the machine a bit so I run them 80% throttle for the first hour or so. Just take it easy.
A slight warm up is done always when they are first fired up to get the oil flowing. Don't beat them to death when you first run them if they are not up to full temperature. Listen to the motor, if it's laboring some, back it off a little.
Most importantly, change the oil and filter when you should.
