Re: Electronic Clutch Dis-Engages-- FINAL CONCLUSION
The several replies that referred to the PTO Switch potentially being the main source of the problem were completely correct in their Diagnostics and Opinion.
Today, I disconnected the connection from the wiring harness to the 2 wires that goes to the PTO Clutch. I Used an in-line fuse in the positive line in the revised wiring directly from the positive battery terminal through a Toggle Switch to the PYO Clutch positive wire. Installed the ground wire to chassis.
Then, I gave the mower a test drive of leaf mulching for a period of 30 minutes (or more) and the PTO Clutch did NOT disconnect (turn off) even one time. Therefore, this is enough evidence (for me) to place the main original problem as being the PTO Switch.
This (modified wiring) of course does NOT require the ON/OFF switch to be ON in order to engage the PTO just by flipping the toggle switch ON. So, I plan to order a new PTO Switch and replace the defective switch and return the wiring to the original connection with the wiring Harness. I will (of course) keep the modified wiring and switch in case if needed in the future.
Thanks again to all that commented to help.
My Regards, Vern....
Good tip Bert....
Nice thing about all the electro-magnetic clutches is, most aren't rebuildable.
