One would have thought that Sears would have at least picked a mower with good crimps on the wires.
Those are pretty bad.
I really hate professional videos that are only 1/2 done .
So he tested each of the switches that Sears sells but failed to test the wiring between the key switch & the brake switch and the brake switch & the PTO switch.
Measuring resistance is always problematic particularly on old mowers with a healthy oxide layer on the terminals.
This is why when I go through these proceedure I ask people to jump the B & S terminals on the key switch plug then check for voltage.
This is easier because you do not have to pull the plugs off the back of the switches all you need to do is back probe each side
I think it's geared towards novices like myself. When I found it, it gave me a better understanding of all the switches involved and it helped me solve another problem with the old mower I'm working on now. Now to an obvious, seasoned vet like yourself, it might not be of much help :smile:
