Sorry for being slow guys, but I've been very busy, and I'm old & broken down as any you'll find . I didn't get to work on it today at all, but we'll get there . I checked all but one safety switch (I think), and all have checked good so far, with no change in problem .PTO is the manual lever engagement, and the switch checked good . The only one I think I lack is the brake switch . I've checked (with multimeter) PTO, parking brake, reverse switch, and seat switch . Still have got the brake switch to check, is there another one somewhere ? I did notice the seat utilized several green wires that I presume are grounds, so I'm guessing if bad it could cause loss of a ground . The fuel solenoid works with a solid click, but the starter solenoid shows 2 hot wires instead of 1 being a ground, same as hour meter & headlights . I sincerely appreciate all the help, and maybe this rings a bell with someone else to comment . Thanks Again !
