OK, my first time to post here so cut me a little slack if I unintentionally go astray . My cub cadet has served me well for 5 years, but have an issue this Spring . Last week my mower started an ran fine all afternoon, no issues noted . When I came back the next day to complete the job, the mower wouldn't start, crank over, anything . I check the under seat fuse (25 amp) and it was blown . I replaced the fuse, and it started and ran fine that afternoon . I was still concerned about blowing a 25 amp fuse . Now, the fuse is not blown, but won't do anything again, even the headlights won't come on . I couldn't hear the starter solenoid click, and it being a cheap part, I replaced it with a new one . After installing it I had gained nothing . With the switch on, I have power to both small terminals and of course the feed wire from the battery, but it never makes up to send fire to the starter . I shorted out the 2 bigger cables to crank the engine over, and it indeed did that but didn't sound healthy at all . The switch is working as I can hear the fuel solenoid click . Out of curiosity I checked the wires (1 red,1 green) going to the headlights, and both show to be hot with switch on . I figured the green should have been a ground IDK, but they don't light up . Let me shut up wondering and turn this over to you guyz for questions . Thanks for any helpful suggestions .
