CyrusSmith
 - May 20, 2021
- Threads
 - 1
 - 4
Hi all!
I purchased a new wiring harness (part # 103-6568) & starter (forget the part #) to go ahead a rule out those problems. I also have purchased a new parking safety switch (part 1-513051) as well as a key switch (part # 103-0206) and a seat delay module (part # 103-5218) one part I have not replaced is the "tilt switch elimination kit" or tilt switch (part #112-8349, or 1-633782 or 109-4577 depending where you look). I also replaced all the relays.
I hooked up all the new parts and just bypassed (using a piece of wire to sort of "jump" the safety harness if you know what I mean) the safety's for the L and R drive handles and the seat switch, having not replaced these switches I figured bypassing them would help me make sure they weren't a problem. And now I am still just getting a click every time I turn the key switch (which is the same response I was getting with the old harness and parts :/).
1.I might have a bad Tilt switch. I know its part of the safety system somehow and therefore could be causing the engine not to want to turn over. Im probably going to replace this part.
2.(don't even know if this is a thing you can do wrong) I am not sure which was the relays are supposed to be inserted into the harness (there are 3 relays) I put them all in the same way and they fit, but I think they could fit multiple ways---so im not 100% sure they are in there correctly, that could be an issue?
3.Anything else you can think of?
In addition to getting advice based on the info I have provided above on what is the problem and how to fix it I am interested in finding a (relatively) easily understandable break down of how I might do a full diagnostic test on the electric system to determine why im not starting (IE check for X volts at a certain point on the key switch, then Y volts at the next point, etc. etc.) FWIW I am not an electric expert, I do have a decent multimeter but if you have to do anything other than DC/AC volts setting I would really need some detailed instructions on what setting etc. to use to check any of the points I should be checking for power)
Finally, to explain where I am at right now: I get a good "click" at the starter when I turn the key switch, the battery is decently charged but I get nothing else.
Engine won't turn over at all I feel like its some kind of a safety problem (the only thing I haven't bypassed or replaced I think is the tilt switch so maybe that is the issue) but I don't know. Any thoughts?? Thanks all!
