Ok, so i can SEE, and can kind of touch (with my finger tips), the parking brake connector, and i can SEE and partially touch (with finger tips) the right side control arm interlock connector.......but that is going to be a MARTYR FLOGGER to route..... On each side, where i reached up (indeed it's from underneath like i was asking), it goes into the square stock of frame under the seat and has a "solid panel" (except the hole it comes through) just a few inches beyond them (on either side)........ EVERYTHING else, is now connected/wired up on the new harness, just those two plugs to somehow get to. Included the pics (as promised) of where it goes down into the frame like i was talking about.........
EDIT*** I forgot to mention, i'll have to go to the shop that looked up the regulator/rectifier for me to see if i can't get the short ENGINE harness that goes from the regulator/rectifier, down to the main wire harness. THAT plug, that connects on the main HARNESS side, but also to the rectifier plug on other end of it , has/had a HORRIBLY burnt female socket and i'm gonna look tomorrow but i would almost BET, it's the light blue, or yellow wire position (one of which, i don't remember, sends the voltage back to charge the battery). If you remember from my FIRST posts about killing battery and not charging? I wonder if THAT plug has been the problem the WHOLE time and i replaced the rectifier AND harness and HOPE i don't still have issue. That short engine harness i'm speaking of, looks like it grounds to the engine on that side also (right side, or else he just did that) and then the temp sending unit wire/plug goes snaked through engine over to it's position on left side from off that short harness too. temp guage hasn't been working since i got it either so i'm going to have to track that short harness down too i think.....
