TheVirginian
Ok, so here's the skivvy.......I bought (TRADED for, rather) a WELL used STT61A-27KA Turf Tiger. I traded BRAND NEW hot AND cold power washing equipment ( commercial, 4300psi, 4.0gpm) and was ASSURED the Scag was good to go and ready to rock. I did the test run around his yard and it started, drove, and cut perfectly. So i load it on the trailer (2.5hrs from home i drove). I get it home, unload it and make a quick pass up my side yard hill and back down and thought "hmmm, i have enough daylight i could get a GOOD portion of the field done" (the MOST of my grass, about 2.75ac of my little over 5ac, the rest is steep wooded hillside). I get to the bottom of my steep driveway and the dang thing cut off in the middle of the road. Pulled arms back and outward, set brake, SHOULD have started but nope, deader than snot...... I pull the battery, which i JUST notice at that moment has a 4/19 sticker on it (brand new at that time a month ago) and put it on charge. Yep, it was a dead (brand new) battery. Think nothing more of it, except that maybe i left ignition on all the way home? and go to cut the field. I get about 1/3 of my field done and the dang thing dies AGAIN. Guess what?!?!? Dead battery....... I go ahead and just BUY a battery and core that brand new one in exchange and get another 1/3 of my field cut and it died again. I take the battery out and go charge it again and bring a voltmeter with me this time to try and figure out is it the regulator/rectifier or WHAT is going on that it's killing the battery so fast?!?!? Well, guess what? now, the dang key wont even turn and i king kong'd it a little and it DID turn but broke internally (not the key, the ignition, lol, oops?!?!?).
So, i get a new ignition switch in, and bought a new regulator/rectifier, and went ahead and bought a PTO knob replacement, and the relay in there as i got ALL that for less than $50 and it was a GREAT place to start.... I put the ignition switch in first, and then the regulator/rectifier. NOW, it starts fine (haven't actually checked charging or not yet, because.....) but as SOON as you engage PTO knob, blows main fuse.........I put two new inline waterproof fuse holders and fuses in, still same..... So, i put NEW PTO knob on, and relay, and a new fuse and try again. SAME THING!!! I talked to my local shop (also a family friend) and he's saying wire harness is burnt/faulty somewhere and/or electric PTO is kicking out too much voltage. I now have BOTH of those in my possession ($500+ dollars later......) but I wanted to see if anyone else here has had a similar issue with their 27hp Kawa and 61" turf tiger setup? I'm not sure even though it SAYS it's the same part number, that the regulator/rectifier is the right one. Just because it looks like it, and has same plug/pin connection, doesn't mean it was wired INTERNALLY the same to those pin designations, or am i just over thinking that? Thanks in advance for any help provided.
