Chenglishguy
- Sep 9, 2013
- 1
- 2
mower was brought to me by a friend and said it wouldn't start, he had purchased and installed a new ignition switch...still wouldn't start or even turn over. After checking a few things I found a blown fuse, continuity checked the switches, solenoid and wiring and all checked good... turn the ign. sw. to start and it instantly blows the 15 amp fuse. The mower is a 01996 Scott's brand 17hp/42in., i'm at a lose with this particular elec. problem! (Checked the common ground also):confused2:
Thanx,
Chenglishguy
Thanx,
Chenglishguy
